I have a problem with the microstation. Accudraw does not appear in the program even if you press the toggle accudraw icon. I would like to know how to solve this problem
Hi Mauricio
please check if the AccuDraw setting 'Floating Origin' is enabled. More information is available in following wiki article:
https://communities.bentley.com/products/microstation/w/microstation__wiki/15831/accudraw-compass-is-not-showing
