How do you change the size of the grips and pointer (the circle on the pointer arrow)?
For the circle at the arrow/pointer: File->Settings->Preferences->Input - Locate Tolerance: It's normally set to 10.
Thank You Stephen, that fixed the pointer size, now I just need to set the grip size.
In MicroStation the grips are called Selection Handles. I do not believe there is a way to change their size.
Rod WingSenior Systems Analyst
With the increasing resolution of screens, I am finding these handles are disappearing into the background.I do not wish to reduce resolution (seems defeatist to me) so is it not about time that this feature was requested?I see a V7 Ask Inga tip to change weight 8, but this no longer applies.
Greg Smith
Microstation 10.17.01.058
Opinions expressed are my own and not necessarily those of my employer
Gregory Smith said:Is it not about time that this feature was requested?
Post an Idea!
