I followed all the steps bellow and still not showing the new level on the sheet file
Global Display controls the display of levels for all views. View Display only controls display for the selected/active view.
Are these levels in a nested reference or are they a direct reference?What is the setting of your MS_REF_NEWLEVELDISPLAY variable, and how is your "New Level Display" set?
Are the references and your active file DGN, DWG or a combination of both?
MaryB
are you ref attaching to the model and then ref attach model to the sheet as a nested ref or are you attaching direct to the sheet?
IMHO your workspace config needs to have new levels display set to the MS_REF etc set to =1 then its automatic in the ref manager you don't change it see below wokspace config so after you added your ref and later you add new levels in your ref and come back to your drawing all new levels post attachment time will now display on your drawing.. if not set to 1 will not display and no save settings needed...
Lorys
It doesn't show in my workspace configuration list.
Thank you,
Lucilia
Hi Lucilia,
Lucilia said:It doesn't show in my workspace configuration list.
What product and version do you use?
If I remember right, MS_REF_NEWLEVELDISPLAY should be defined (should exist) in V8i products, but with undefined value:
When the variable do not exist, you can create it and assign its value (MicroStation restart is typically required in such case).
Jan
I'm using Micorstation V8i SS10.I found it. Thank you!
