Never used this tool before, but unless I am missing something really obvious it produces nonsensical output for me.
In attached example I have created a new file from seed3d.dgn, and placed a line with keyins: XY=0,0,0 ...
The expected result is a line with start point at coordinate X=0, Y=0, Z=0 and this can be confirmed in Element information Tool.
However XYZ Text insist on different interpretation.
Best Regards,
/Chris Z.
Brien Bastings: There is a separate set of "export useacs [on/off/toggle]" key-ins.
Thanks, thanks & thanks!
Are there any plans to actually INDICATE the active setting in Tool Settings?
Cheers,
Chris Zakrewsky: Are there any plans to actually INDICATE the active setting in Tool Settings?
Actually the USEACS keyins will be going away for XYZTXT in the next update. XYZTXT will instead use the ACS lock to determine whether or not to use the active ACS.
-Mark
Thanks again.
I am marking this thread now as SOLVED.
Best!
