First off to explain the issue I'm going to walk through our work flow on how we create a 2D drawing in Microstation from a CADWorx Structures 3D model.
I am currently running update 13 and have also tested this method on update 14 and this method works well for us. A few co workers have got new machines which had Microstation re-loaded and now they run update 15. In update 15 this method has somehow broke, the referenced saved view in the 2D file will not display as the display style it was given (hidden realistic) in the reference dialog box. Again, we are not having any issue when using update 13 or 14, this seems to be only happening in update 15. I know many probably don't do this exact same workflow but has anyone experienced something like this? Is this fixed in the newest version of update 15?
What format are the CADWorx files that you're referencing into the MicroStation files? Are they DWG or DGN? Is it possible for you to provide some example files for testing along with some screen capture to help understand what is happening with the display of these line types?
user submitted SR # 7001248644 waiting for user to send test data.
