Hello All,
My organization already has the AutoTURN Pro button loaded under an organization ribbon.
However, when I click on it. It says "MDL Loader: Could not load application atcn". Check the picture below.
I was able to troubleshoot to some extent and I feel I have figured out what the issues might be. I believe the issue might be either no space between the "mdl load atcn;mdl unload atcn". I believe it should be like this "mdl load atcn; mdl unload atcn". Or the issue could be the source. Any and all help is appreciated. I would like to change the key in command but I am not sure why it is greyed out. I am not able to modify that.
Hi Nishant,
This post may help:
https://communities.bentley.com/products/microstation/f/microstation-forum/174122/launching-autoturn-in-connect/621352#621352
Mary & Lorys are correct, you can't combine the load and unload commands in a single button. We use:
"Mdl load atcn;ribbon rebuild" to load AutoTurn and refresh the ribbon with the AT ribbon tan added and;
"Mdl unload atcn; ribbon rebuild" on another icon to unload it and refresh the ribbon without the AT ribbon tab.
Please note that the AT dgnlibs have named expressions that should only show the AT ribbon tabs if the mdl is loaded and configuration variables should be set in your workspace that point to the paths of AT to allow the mdl load command to load it correctly.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
