Hello, I'm looking a way by using key-in(s) to change the angle of multiple selected text to 0° or any other angle defined by me.
I know about program ActiveAngleAssistant, I'm interested in key-in(s).
MicroStation V8i (SS3) 08.11.09.292
The required angle of the selected elements should be filled in manual by the user in the Element Information dialog window.
If you try recording a macro by using the SelectBy dialog to select your text, and the properties window to set the angle of them all, you may be able to uncover the commands you would need to run in your batch process. Not the macro, but the command the macro records while you do what you need to do. Once you have found those commands, you can try them in a command file for a batch process.
MaryB
Just recorded a macro:
! selected any text angle 56° => toggled element info dialog window => changed element geometry angle to 0°As you may see in the code below, no useful keyins captured :)
Sub Macro1() Dim startPoint As Point3d Dim point As Point3d, point2 As Point3d Dim lngTemp As Long ' Coordinates are in master units startPoint.X = 150114.013039893 startPoint.Y = 208916.416886794 startPoint.Z = 1.3271346688E-10 ' Send a data point to the current command point.X = startPoint.X point.Y = startPoint.Y point.Z = startPoint.Z CadInputQueue.SendDataPoint point, 1 ' Start a command CadInputQueue.SendCommand "MDL KEYIN elementinfo element info dialog toggle" CommandState.StartDefaultCommand End Sub
If there's no command that equals "change this property of an element" (which there may not be) you may not be able to achieve what you want.
That being said, you may be able to leverage one of the ActiveAngleAssistant macros through the keyin to load and run the macro that will rotate text to 0 (or to active angle which you can set to 0). You may be able to create your selection set, load/run the macro, and if it needs to, send a data point to accept, then "choose none".
I am not in Microstation today, so I can't look those up directly.
If you have some VBA programming experience you can start with the following sample code in the VBA help.
Open the VBA help file “MicroStationVBA.chm” from the following locationC:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\MicroStationVBA.chm
Search for a sample code "Rotating an Element Example"
