I have to upgrade Mictrostation v8i SERIES 4 to SERIES 10.
I need a file with the extension: : Microstation v8i SERIES10.MSI.
Can you tell me where I can download from? because I can't find anywhere...
BR
Hello Grzegorz,
This is the Hevacomp forum for issues / queries relating to Hevacomp software.
I will request that this post is moved to the MicroStation forum however this may take a little while, so for a quicker response you may wish to post to the correct forum here.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Post moved to the MicroStation forum for follow up
Below is a wiki explaining how to download MicroStation V8i SS10. I do not believe it is a .MSI file, but a .EXE
https://communities.bentley.com/communities/other_communities/licensing_cloud_and_web_services/w/wiki/30658/software-downloads-instructions
Fernando
Hello Fernando,
When you extract the file the inside will be microstation.msi
