MicroStation CONNECT Update 8
Does the Label tool have it's own variable to limit the cell libraries that it lists available cells from?
Currently it appears to use MS_CELLLIST which in a lot of companies will have lots of cell libraries listed for different purposes.
If not already, can this be updated to have it's own dedicated variable for either cell list for dgnlib list.
e.g. MS_LABELCELLLIST= or MS_DGNLIBLIST_LABELS=
If MS_CELLLIST contains lots of cell libraries and lots of cells, then the label tool when selecting the drop down will crash MicroStation.
Hi Stephen
See this forum post on MS_CELL and MS_CELLLIST and strategies for how you might use these variables:
communities.bentley.com/.../ms_celllist-vs-ms_cell
Hi Grzegorz,
MS_CELLLIST will list available cells in the drop down on the Cell manager.
It has been co-opted to be used to produce the list of cells within these cell libraries for the Label tool.
The Label tool needs it's own variable to limit which cell libraries are available for label cells.
MS_CELLLIST can have cell libraries in it with hundreds of cells un-related to labels and causes MicroStation to crash when you select the label tool and in the tool settings try to select a label cell.
I very much agree with Stephen, this is a major problem when there is several hundred, or thousands of cells in the libraries in the MS_CELLLIST. It deems the Place Label cell filter useless as it always crashes MicroStation (V10.16.02.34).I am sure I raised this a few years ago and it is still not fixed
Stephen Holmes said:Does the Label tool have its own variable to limit the cell libraries that it lists available cells from?
John Davidson said:This is a major problem when there is several hundred, or thousands of cells in the libraries
Post an Idea!
I have raised Enhancement (Product Backlog Item) # 870862 for our development team to investigate the possibly of including a new configuration variable to limit the cell list on the Place Label tool to Label Cells.
Product Backlog Item 870862: Place Label - Cell Name filter issues with large list of cells
