Good morning. I just created a simple polyline this morning, and the software won't let me delete it. PLease advise at your convenience. Why would a software do this ?
Thank you.
John Griffin said:I just created a simple polyline
John Griffin said:Why would a software do this ?
What software? A polyline is an AutoCAD entity, in which case you're asking on the wrong Forum.
Its' a Bspline curve and its' on a locked level
Jon Summers said:What software?
Assuming that you're using MicroStation, what version of MicroStation?
John Griffin said:It's on a locked level. The software won't let me delete it
Search for Lock in this help page.
Microstation V8. I figured it out. Took me about an hour though. Thanks.
John
If you open Level Manager and right click on the column headings, you will see an option to expose Lock. With this visible, you can unlock the level and then delete the line
Ian
