I recently updated to MicroStation Connect Edition 15 (version 10.15.02.11), and now every time I open a DGN file, the Main toolbox is not on. I've tried turning on the Main toolbox, saving settings, closing out, reopening, and the tool is unchecked in the Tool Box menu. I've made sure all settings files are able to be overwritten. I've never had this issue with previous versions of MicroStation. Anyone know of a solution?
Hello
this issue has been already reported as a defect #1115302 and has not been resolved yet. The workaround solution is to use the V8i Task Theme:
https://communities.bentley.com/products/microstation/w/microstation__wiki/43148/enable-v8i-task-theme-in-microstation-connect-edition
Answer Verified By: Anne Fendick
I have a few on, and they stay, but "MAIN" seems special, it won't stay, as you say. I might suggest you learn to use the Ribbon. The Task Navigation is fairly "clean", you can add commands using Customize Ribbon. Not that I like the ribbon, but it's here to stay (maybe). Coming all the way from IGDS, I'm used to adjusting to new UIs.
