I want to collect information from a number of files. I don't want to modify those files. If a file is read-only (e.g. Windows file protection) then I see a modal dialog like this...
With a batch operation in progress, that dialog requires human intervention, which hinders the automatic process. Is there a way to suppress that dialog?
You are not alone - communities.bentley.com/.../598763I have used workaround to start batch process with key-in: DMSG ACTION OKAYBut it doesn't supress the window just clicks OK button. Knowing that Bentley indexing/batch tools have same issue with modal dialogs it seems there is no option to suppress them.
Known dialogs which interrupt batch process:
