Everyone,
We are using the new MicroStation V8i Connect Edition. I get the following error when trying to use the Cloud by Points command:
"Unknown Key-in Command"
Does anyone have a good fix for this?
thanks,
Warren Murray
South Carolina, USA
Same here. Both Cloud by Points and Cloud by Element tools give that error.
MS CE U15.02.11
Rod WingSenior Systems Analyst
As a workaround user can use key in: place revcloud element
and also We can use the tool box ‘Cloud” from File menu \Settings\Tool Boxes and select Cloud and from there cloud by elements.
As a workaround user can use key-in command: PLACE REVCLOUD POINTS
and also can access same tool from File \Settings\Tool Boxes and select Cloud
Important note: You can also copy the attached DGNLIB file to C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\Organization\Dgnlib\Gui and restart your MSCE to correct this issue.
CorrectRevCloud.dgnlib
Maria Garcia
