Version 10.15.2.11. I have tried to run batch process non-graphically, but every time get the error message like in subject. Even if I had commented all lines in command file. I noticed some one asked about this back in January, but couldn't find any solution for this? I am running Windows Server 2019. Graphically inside MicroStation the same bprc works just fine. But not with command like "start /wait MicroStation.exe -wabatchprocess -iD:\test.bprc"
This type of error is related to an inadvertent inclusion of a "Trace Logging" script in this release. This has been rectified and testing in the next release of MicroStation CONNECT Edition (Update 16) has confirmed it is no longer occurring. The new version should be released very soon.
https://communities.bentley.com/products/programming/microstation_programming/f/microstation-programming---forum/208632/log4net-error-when-calling-mdlsystem_newdesignfile-in-microstation-10-15-00-74
Thank you for the quick reply! In the mean time, should I move to version 14? Or does the current version still execute the commands in the command file even this error occurs?
I would suggest executing this from within MicroStation until Update 16 has been released which will be very soon.
