One of our users has a site plan model with hundreds of levels (z elevations) that he wants to change by a certain amount. For example change 119.00m to 119.20m.
I seem to recall that a number of years ago someone posted a macro that did this, but can't find it following a search.
Any ideas how to do this or does anyone have a macro that does this?
Hi Stuart
There is a tool called MODZ. its an MDL, it was updated for CE a while ago, you should be able to find it in the files section of the forums. if not let me know
Ian
Ian,
I had a quick look but couldn't see anything obvious!! Could you forward a copy over to me. TIA.
I will dig it out... FYI Jon Summers has a version
http://www.la-solutions.co.uk/content/CONNECT/MVBA/MVBA-ModZ.htm
You could also use the distance keyin:
XY=#,#,#-0.2
or
DL=0,0,-0.2
I believe that Connect also has a "Set Elevation" tool (although I could be thinking about OpenRoads) that is based on the old CivTools.
MaryB
Ian Lapper said:I will dig it out... FYI Jon Summers has a version
Thanks.
