I am trying to make a text favorite to label regions that we create for area calculations
The properties of the region call it out as a "Complex Shape" but when i use "Complex Shape" as the Field Sub Type and select area I get an "Element not valid for tool"
Any thoughts?
Brian
Microstation CONNECT - 10.15.02.11
Brian Gregis said:TextFavorites.dgnlib
I was able to manually annotate the two complex shapes in your DGN file. See attached...
6521.TextFavorites.dgnlib
Yeah. Thats my problem
Trying to get a text favorite to label a complex shape created by region
Brian Gregis said:Trying to get a text favorite to label a complex shape created by region
Krister Surell concurs: raise a Service Request with Bentley Systems.
I've reported this and defect 1123517 has been logged for this issue!
/Krister
Owner consultant at Surell Consulting AB
Brian Gregis said:there are times that we need an area quickly labeled
Consider using AreaAnnotator.
