I am trying to make a text favorite to label regions that we create for area calculations
The properties of the region call it out as a "Complex Shape" but when i use "Complex Shape" as the Field Sub Type and select area I get an "Element not valid for tool"
Any thoughts?
Brian
Microstation CONNECT - 10.15.02.11
Thanks Krister
Thanks Kriter
I tried the reports and it spits out a nice table but now i have to hunt down the what parcel it is referring to. I thought to label it with the element ID but it is not liking the complex shapes with curves for some reason that were made by region
Brian Gregis said:I tried the reports and it spits out a nice table but now i have to hunt down the what parcel it is referring to
The table should be reactive. Click on a row in the table and the corresponding area element should hilight. If that doesn't work for you, post a new question in this Forum, preferably with an example DGN file.
