CE15.2
For years I've been annoyed that on occasion snaps didn't work but I could not figure out what the cause was. If a filled shape exists in 3D space above a element in CE and you attempt to snap to the element snaps will not work even in wire-frame. Under users>preferences>input> Locate interiors is set to never. Is this intentional or an oversite?? Attached file for others to try maybe it's just me?
cannot_snap.dgn
-Grant
This has also been an issue for me - I've tried to get to the bottom of it with this thread; communities.bentley.com/.../594681
... but without a solution I'm still using v8i to remain productive.
As a summary of the problem (using your file), see below. I really hope someone could provide a solution to this.
Well I tossed up an idea maybe if it gets enough traction we can get it fixed.
Grant Wood said:Under users>preferences>input> Locate interiors is set to never.
If you set that to visible, it does snap.
Connect r17 10.17.00.209 self-employed
Bob Rayner said:If you set that to visible, it does snap.
Correct - but not first time... it snaps to a point on geometry that Microstation deems more "selectable" based on its proximity to the camera (in this case, the circle). Only a second attempt will snap to the point I'm aiming for.
I don't want Microstation to second guess my intentions. I can see the red cube - I want to snap to a point on it - it worked perfectly in v8i - why must I change a user preference to get it to "sort-of" work in CE?
I agree, more over if making dynamic views with 3D geometry you need this set to never or it makes annotations impossibly time consuming.
