Just wondering if there's any keyin's equivalent to the V8i "accudraw shortcuts readfile" keyin?
Best regards,
Tuan Le
Check the following AccuDraw, Connect key-ins documented in Help
Complete List of AccuDraw Shortcut Key-ins
I've checked and couldn't find any Leonard, hence my question.
the file is located in your preferences here: %localappdata%\Bentley\MicroStation\10.0.0\prefs
File is named Personal.KeyboardShorcuts.xml
Thanks Mark. I have no trouble locating the xml file. What the V8i keyin does is reloading the shortcut key text file mid session. Currently, if xml file is edited while Microstation is opened, I have to restart Microstation to reload the updated xml file.
Hi Tuan,
Tuan Le said:I have to restart Microstation to reload the updated xml file.
it seems you are right:: the keyboard shortcuts definitions are loaded only when MicroStation loads workspace. It's not exactly "to restart microStation" as you wrote, because the file is reloaded also when a file is closed (but not MicroStation) and a new file (plus workspace/workset optionally) is selected.
Tuan Le said:if xml file is edited while Microstation is opened
May I ask what is behind this request and workflow? It looks unusual to change shortcuts at runtime.
With regards,
Jan
