I have complex chain elements that contain lines, curves, arcs and b-spline components. When I export them to AutoCAD I get SPLINE elements in the DWG file. If I drop the complex chain to its components before exporting I get separate components in the DWG file. Is there another way to get this result without exploding the chains?
Most likely not as unfortunately lot of DWG conversion options are hardcoded in Microstation and are not user configurable.
