Component Center Import models/cellibrary
Hi
We are thinking about moving from traditional cell libraries to Component Center.
If I have a cellibrary->How do I import each model to Component Center (including model name/description) without doing this individually for each model?
Possibly I could split it up into several dgn files thru some batch process and use web interface to import. But then I will lose the description. Anyway to import description in the web interface?
Running Microstation CE Updt 15
