Hi
We are thinking about moving from traditional cell libraries to Component Center.
If I have a cellibrary->How do I import each model to Component Center (including model name/description) without doing this individually for each model?
Possibly I could split it up into several dgn files thru some batch process and use web interface to import. But then I will lose the description. Anyway to import description in the web interface?Running Microstation CE Updt 15
multi-upload was added as adhoc feature to fulfil requirements where some of the information (Name & Description) wasn't necessary and multi-upload components belonged to same group (category, catalog etc) and it served that purpose. A batch upload/download feature is planned but given the bandwidth product has - not sure when that gets scheduled.
Thanks all for your inputI guess the key thing I wanted to point out here is that we probably are a lot of users that have been using Microstation for many years with already existing extensive structured cell libraries/libraries of dgn files(and also metadata). Basically what we can do right now is only import models. Well, there are some functionality for this.What I really would like to see is some kind of metadata import/export functionality.
