In Connect 15, when copying and incrementing a number with more than 4 digits, the C&I tool automatically inserts a comma to break the number up into 3 digits. For example, if I start by placing the text value A1000 and want to use C&I text to add numbers, the tool does the following A1,001, A1,002, etc. Is there a way to override this and remove the comma?
Hi Steve,
I do not see this behavior in CE Update 15.2, texts are incremented "normally" without digits split.
Do you use U15 or U15.2?
Maybe there is a dependency on Windows local formatting setting?
Jan
You might check Windows number format.
Thanks. That fixed the issue.
