Everything I have found about turning off the WorkSet Mismatch Alert in MS U15 seems to indicate that the only option is to turn the alert OFF, and use the WorkSet the DGN is branded with when it is opened.
Is that really the only option?
We were assured in a Service Request to Bentley that there would be/was an additional option to turn it OFF, and use the user's currently Active WorkSet when the DGN is opened.
We needed both options, and have been waiting for MS U15 to provide some relief.
Could someone at Bentley let us know exactly what the option(s) really are?
G,Houck
glhouck said:We were assured in a Service Request to Bentley
Did you post Idea (or searched for the same or similar ideas)? It allows to comment and vote to support it.
Jan
Hi, Jan,
First, I posted this to the wrong Forum, then when I found similar, but different complaints, I wasn't sure how to post the complete thing in the context of a Reply, but I will try to do that.
I don't post much anywhere, so I am a relative noob out here, embarrassingly so.
G.Houck
glhouck said:I don't post much anywhere, so I am a relative noob out here, embarrassingly so.
I am sure you will gain experience quickly :-)
glhouck said:I posted this to the wrong Forum
For some issues, it's not clear what forum is the best (e.g. whether it's MicroStation or Product administration). In such case, to use this one, is preferred option.
For ideas (requests, what should be added to MicroStation) there is dedicated forum.
Here is a discussion about the "Enhancement Request" Bentley has on file: https://communities.bentley.com/products/microstation/f/microstation-forum/200094/workset-message-when-opening-file/597381#597381
MaryB
Microstation 08.11.09.919Power GeoPak 08.11.09.918Power InRoads 08.11.09.918
Thanks, MaryB. Your link goes to Andrew Bell's response, which has a link to Enhancement 1060165, from which I get a 'tfs.bentley not found'.
I was told by Bentley to add our name to the enhancement request, and I will scope that out.
Thanks again,
