I think the Ideas Forum is a great idea!
If I want to point someone towards a particular Idea, I would like to provide a link (or URL). However, I notice that wherever you are in the Ideas Forum, the URL is always the same: communities.bentley.com/.../i.
For example, suppose I want to direct someone to vote on my Idea MS-I-399. How can I do that? Perhaps Eduardo Lazzarotto can comment?
MS-I-399
Hi Jon,
You can right click on the link you used to get to your idea and copy it, and then provide that copied link (or URL) for others to go directly to your idea.
Regards,Ron
Answer Verified By: Jon Summers
That's not a particularly elegant nor intuitive solution. Why is "the link you used to get to your idea" not the URL in the bar above?
MaryB
Ron Jones said:right click on the link you used to get to your idea and copy it
Thanks! For example, microstation.ideas.aha.io/.../MS-I-399
MaryB said:That's not a particularly elegant nor intuitive solution
I agree.
That is because it is frame much easier is to use aha.io portal directly. Ideas section embed in communities is not elegant and creates tab view inside tab view.
Thank you very much for reaching out. As Oto mentioned, you can find the idea link by accessing it directly via https://microstation.ideas.aha.io/ (like this one that you submitted: https://microstation.ideas.aha.io/ideas/MS-I-414).
But I fully agree with you, it would be great to easily share the link directly from the embedded UI, so I have shared your idea with Aha: https://big.ideas.aha.io/ideas/A-I-10934.
Best regards,
Eduardo L
