Dear team,
How to move border (reference) and including content to X & Y = 00 Level for multiple sheets, there is 10 thousand sheet need to Comply, your support highly appreciated.
Thanks, & regards.
You will need to look in the Help file and find the commands to do the following:
move the reference file
data point at your current offset
Data point at XY=0,0
Select all
move element
data point at xy=0,0
select none
Once you can type those commands into the Key-in dialog and they give you the result you expect, you can save them into a text file which you will use as your Command File for the Batch Process utility, which can be run on many files as long as they are all the same.
MaryB
Answer Verified By: Anwer Nechikkad
Thank you for your valuable reply,
From reference I have set offset XY= 0,0. but i could not able to work this comment in Key-in, could you please advice me which comment need to give Key-In to move reference and object to 0,0.
Thanks & Regards
Anwer Nechikkad said: please advice me which comment command need to give Key-In to move reference
REFERENCE MOVE
