Hi All,I'm wondering if this is possible or not, i created a section cut on a segmental bridge, the decks are divided into different pieces. (See snap below)Normally what would happen is the segments will also be divided in the section, but is it possibile to display it as a single object with the divisions removed?
Microstation CE Update 14
Many thanks,
Cris
You would need to use OBD to be able to unify parts as Microstation does not have this ability. You would have to unify the solids to achieve this in MS
