program does not save settings. How do i solve this ?
I can't get the program to save settings and top menus do not show
Hi Abner Martinez,
Maybe a UPF corruption.
you could try different things:
1. Reset the personal.upf-> this is saved in C:\Users\{Windows UserID}\AppData\Local\Bentley\MicroStation\10.0.0\prefs\Personal.upf
UPF (user preference files), it is where all your preferences are stored https://communities.bentley.com/products/microstation/w/askinga/1002/1002
2. Check if restoring MicroStation to factory Defaults resolves the issue https://communities.bentley.com/products/microstation/w/microstation__wiki/8671/restore-microstation-to-factory-defaults
You can use the option 2
Maria
Maria Garcia
Abner,
UPF stands for User Preference File. It is the a file that usually keeps all user preferences, from withi MicroStation environment.
And when you delete it you will need to redo all your preferences you've changed (if any). Once you get it back to where you need it, make a back-up copy, for some reason that file gets corrupted from time to time.
