MDL FINDREPLACETEXT BACTH PROCESS AND CHANGE THE COLOR OF THE TEXT
I WOULD LIKE TO SEE IF I CAN GET HELP CHANGING MY TEXT IN ADDITON TO CHANGING THE COLOR OF SAID TEXT STRING IN A BATACH PROCESS? I FOUND THE BELOW MDL CODE TO BE LOADED AND IT HELPS TO REPLACE A CERTAIN STRING OF TEXT WITH MULTIPLE DRAWINGS. HOW DO I ALSO CHANGE THE COLOR OF THAT TEXT? PLEASE HELP.
MDL SILENTLOAD FINDREPLACETEXT;
FIND DIALOG SEARCHSTRING "XXXX";
FIND DIALOG REPLACESTRING "123";
CHANGE TEXT ALL
(WHAT CAN I ADD TO THIS TO HELP WITH COLOR ADJUSTMENT?????)
