I am currently useing MicrostationConnect version 10.14.00.109. The dgn file that I created has 3 lines one on the lt, center line and one on the right .with different offsets.
What I would like is to create a table of all these different offsets or a report by clicking measure distance command picking the two lines centerline and then the left and doing the same thing on the right.
As a example
Location 1 10.6' lt of centerline 78.4' right of centerline
Location 2 10.622.3' lt of centerline 34' right of centerline
Appreciate some step by step how to crate it.
Steve Smith said:The dgn file that I created has 3 lines one on the lt, center line and one on the right .with different offsets
I don't understand how a line can have an offset. What is offset from what? A screenshot or, better, a DGN example, would clarify your question.
I don't know why you don't understand it is simple. You have 3 lines one the left one on the right and one in the middle with the offset distance distance at both locations. Offset distance is using copy parallel command with the distance you type in.
MicroStation V8i (SELECT series 3) - Version 08.11.09.578
Microstation Connect 10.14.00.109
Steve Smith said:I don't know why you don't understand
Because I am simple?
You have a set of three parallel straight lines. Is that it? Or do you anticipate having many more sets of parallel lines that you want to measure?
Steve Smith said:with the offset distance distance at both locations
You want to measure the perpendicular distance between one line and two other lines.
The result is two distance measurements, which you term 'offsets'.
Steve Smith said:What I would like is to create a table of all these different offsets
You sure like to make things complicated.
Steve Smith said: with the offset distance distance at both locations
I want to measure the distance on the lt. and right of the centerline.
Yes
Steve Smith said: What I would like is to create a table of all these different offsets
Need to clarify
The table will have headers like:
location lt distance offset right distance offset
Location 1 1 0..6' 78.4'
Location 2 10.622.3' 34'
Location 3-23 various various
Hi Steve,
There are only these 3 elements in the file? I assume they are not, and context (how complex the file is) can change the complexity drastically.
Steve Smith said:one on the lt, center line and one on the right .with different offsets.
What do mean "left" and "right" terms for you? In topology (and GIS, cartography generalization and similar areas), left/right is defined in context 1st and 2nd point of the center line.
Steve Smith said:a report by clicking measure distance command picking the two lines centerline and then the left and doing the same thing on the right.
Do you mean you expect to select all lines (center / left / right), always in the same order? So when there will be 20 center lines, 60 lines have to be located? This workflow makes the location issue the simplest possible I guess, on the other hand is not user friendly (too many clicks).
Steve Smith said:Appreciate some step by step how to crate it.
MicroStation is not able to do it. MicroStation reports allow to query elements with Item Types attached (or with other EC data available), and include also defined related information. But lines, created using Copy parallel tool, are independent elements, with no relation to the original line.
I think what you are asking for can be achieved writing own code. Because Tables and Reports are not supported in VBA, probably to use C# is necessary (or maybe C++, because it's MicroStation primary API). To implement such functionality is about balancing between workflow (how it's automated and user friendly) and complexity (to implement detection of left/right lines depends a lot on design file content and structure).
With regards,
Jan
