Dear Expert,
Kindly confirm if i have MicroStation SS10 then can i save the file in lower version i.e in ss4 version.
I want to save the file which can open in MicroStation SS4.
File format is same for all MicroStation V8i and MicroStation Connect versions. Your DGN file will open in SS4
Thanks for the quick response.
Can you please help me to reply on below query?
Vectorization of the drawings from Tiff/PDF/Raster files in to Native Editable files (Micro station V8i series-4 software) is it possible in MicroStation ss10?
Bentley Descartes has these functionalities. Check the following link
Bentley Descartes - Raster Vectorization
Thanks....Can you confirm that it is the part of MicroStation or seperate software??
Its a separate software.
