I am trying to use 'background maps' with EPSG:2019 MTM Zone 10 projection. The aerial map wont display.
However if i change to EPSG:3161 the aerial map displays without issues.
Does the background map function work only with specific GCS?
Microstation CE Update 14 Version 10.14.02.01
Hi Alexandre,
Thanks for reporting this issue. I was able to reproduce this in MicroStation CONNECT Edition Update 14 & 15. I will log a defect for this and will share the defect number shortly.
Answer Verified By: Alexandre de Massy
Defect 1132368 is logged for this issue. If you are going to raise a service ticket for this, ask for it to be linked with this defect number.
I've also noticed this behavior, but it's not consistent, sometimes it just works, but even with the map background, sometimes it just ignores me. Fortunately, I rarely use that feature.
