Shared cell names changed (asterix prefix)
E 1OG - copy.dwg
I am getting DWGs and need to count the (shared) cells.
And I can't because many of them have changed names (?description in microStation). So when "Select By Attributes" is used I am not finding all same shared cells
When I open them in Microstation  [CE15] a number of cells are fine and have their "rightful" name.
But other cells are "renamed" with an asterix. And these otherwise SAME cells have a different name each! (running number with an asterix *U60 ... *U62 ... Why?
I am not able to count these "singled out" shared cells.
In AutoCad I find the VERY elements with their correct names  - even after closing the file in MicroStation !!!
What ist the difference between the "Element Description" in MicroStation and the ""Name" of the Block in AutoCad.
Why is there not the Block Name show in Microstation?
I read about the asterix and unnamed shared cells in other posts. But that is definitely not the case here - or is it? Not in AutoCad obviously!
Parents Reply Children
