Where can I find the settings to change the gap ratio to numbers in microstation v8i ss3 version 08.11.09.587.and windows 10 when measuring the area using the flood option.
Appreciate your help.
.bentley.docx
Hi Steve,
Steve Smith said:to change the gap ratio
There is no "gap ratio" settings, only "gap" in a meaning of distance (gap size).
As Andrew Bell wrote, the format, how values are displayed, is defined by working units settings.
Steve Smith said:when measuring the area using the flood option.
It would be nice to share an example of geometry where the measuring does not work. It's not clear how you working units are set, but 0.00012 of sub unit looks like under standard resolution setting, so probably no gap is accepted.
Please, do not use docx to share images. To open untrusted docx files is generally dangerous (because can be malicious). Why to not attach to the post jpg file directly?
With regards,
Jan
I found the max gap on flood fill create region seemed to work better in v8i than in Connect 13 ... but it might just be my data..
example would be I have 0.02m actual gap in a line ie they are not joined or single line, in V8i I would set the max gap trial and error a few times and it would literally jump the gap and create a closed element fill.. but in connect this is not working for me no matter what number I set.. I just have to go find gaps when it wont fill.. I suppose I should use data clean up flag gaps but the source file is a ref file and i want to create coloured filled shapes in the active file.....anybody else found this or figured it out? My quick fix is to make smart line criss cross over several places in my line work then try and flood file in between until I find the little portion that refuses to fill ie enclosed.. ( by the way arcs in complex lines are particularly sensitive to this not working in Connect 13 for me..
Lorys
ok posted dgn so anybody got solution how to determine what the right number is or really means
I may have stumbled onto something and I don't like my findings one bit...
Looking at your DGN file, there is actually another gap North of your annotated gap.
I work in millimetres and my files always open in that unit so I will continue my post using those values.
The true distance of the annotated gap is 9.55mm (to 2DP)
The true distance of the additional gap is 15.27mm (to 2DP)
When I set the max gap value to 15.27 the region works
I manually tested different smaller values reducing by 0.1 and then 0.01 until I found that 14.79 works but 14.78 does not.
Here comes the bad part...
We all likely expect the gap value to the be the magnitude of the vector from 2No points (i.e. the true distance), however when I dimensioned the gap, I found the largest orthogonal dimension closely matched the value I had determined manually!
Fearing the worst I decided to change the dimension accuracy and max the design file accuracy to 6DP:
It seems my fear is unfortunately true (right click on the image and open in new tab/window for true size):
In the above capture I measure the largest orthogonal distance using Distance between Points, copy the value and paste that in the the Create Region gap box. You can see the highlight shows the outer and inner boundaries are valid and that the region can be created. After cancelling, I reduce the gap by 0.000001mm (one millionth of a millimetre!!) and sure enough the region creation fails.
1 instance doesn't prove anything and could be a freak result, so I used modify element to align the above endpoints and tried the same proof with your original gap. The difference is its smaller and that the largest size is measured horizontally instead of vertically however I found the exact same result that reducing the gap size by 0.000001mm from its X dimension causes it to fail.
Shoddy work Bentley, very Shoddy!
Now my V8i SS10 feels somewhat tainted
Excellent analysis! You provide examples and show your working. If only everyone would do the same!
Did you notice that it doesn't actually try to close the gap but just ignores it and connects to next point. This is what is not expected by users as for area measurements it introduces larger calculation error. Seems this max gap algorithm was introduced decades ago for some specific workflow and has not changed so that is why not possible if it is WAD or bug. Not to mention the tolerance setting which finally was removed in CE but even before that was not working.
I'll just have to use data clean up in a fence to find gaps and overlaps and fix the line work which is what I feared was the problem...
1 - 2 cm gaps in a meters world with road pavements several hundred meters long and 2- 4 lanes wide is tiny error for jumping gaps and creating filled coloured areas for measuring later by levels is not too bad as your going to round up answers anyway.. but I agree this tool should be better and easier to predict ie tolerance actually means something relating to the gap distance permitted... for now the zig zag smart line helps find the gaps a but faster when the source file is a reference file from modelers and i just want to use active file for creating coloured filled regions
