I often get the above error message "unable to display results because an error occurred while processing" whilst its never prevented me from doing what's required, I end up getting a large number popping up.
I've only had this happen on some files, and only since using Microstation Connect.
Is there anything I can do to fix this issue, Its just annoying to see this every time, I work in certain files.
Kindly share a snapshot of the error message and copy all the details to a text file and share. Do also share the exact version details Forum best practices
Have you installed MicroStation Connect with default options.
Error Message: Details
User Supplied Message: Unable to display results because an error occurred while processing the query.A ClosedRepositoryException was thrown: Bentley.ECSystem.Repository.ClosedRepositoryException: Exception of type 'Bentley.ECSystem.Repository.ClosedRepositoryException' was thrown. at Bentley.RuleDrivenPresentationECPlugin.SchemaHelperInternal.IsConnectionSupported(RepositoryConnection connection) at Bentley.RuleDrivenPresentationECPlugin.RuleDrivenContentProvider.UpdateContents(RepositoryConnection connection, IList`1 updatedContentProviderPageableContainers, Int32& totalNumberOfElementsInUpdatedContainer, ContentGroup contentGroup, IAUISelectionControl selectionControl, Int32 pageSize, IDictionary`2 instanceChangeRecords, IDictionary`2 relationshipChangeRecords, IExtendedParameters extendedParameters) at Bentley.EC.Presentation.Content.ContentServiceInProcess.UpdateContents(RepositoryConnection connection, ContentServicePageableContainer& updatedContentServicePageableContainer, ContentGroup contentGroup, IAUISelectionControl selectionControl, Int32 pageSize, IDictionary`2 instanceChangeRecords, IDictionary`2 relationshipChangeRecords, IExtendedParameters extendedParameters) at Bentley.EC.Controls.ContentServiceContentModelAdapter.UpdateModel(ContentServicePageableContainer& updatedContainer, IDictionary`2 instanceChangeRecords, IDictionary`2 relationshipChangeRecords) FROM - (Bentley.RuleDrivenPresentationECPlugin.SchemaHelperInternal, Bentley.RuleDrivenPresentationECPlugin, Version=1.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4) DLL - C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Assemblies\ECFramework\extensions\Bentley.RuleDrivenPresentationECPlugin.dll
Caught by (Bentley.EC.Controls.ContentServiceContentModelAdapter, Bentley.EC.Controls3, Version=1.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4) METHOD - Bentley.EC.Presentation.Content.ContentUpdateStatus UpdateModel(Bentley.EC.Presentation.Content.ContentServicePageableContainer ByRef, System.Collections.Generic.IDictionary`2[Bentley.ECObjects.Instance.IECKey,Bentley.EC.Persistence.InstanceChangeRecord], System.Collections.Generic.IDictionary`2[Bentley.ECObjects.Instance.IECKey,Bentley.EC.Persistence.RelationshipChangeRecord]) DLL - C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Assemblies\ECFramework\Bentley.EC.Controls3.dll at Bentley.RuleDrivenPresentationECPlugin.SchemaHelperInternal.IsConnectionSupported(RepositoryConnection connection) at Bentley.RuleDrivenPresentationECPlugin.RuleDrivenContentProvider.UpdateContents(RepositoryConnection connection, IList`1 updatedContentProviderPageableContainers, Int32& totalNumberOfElementsInUpdatedContainer, ContentGroup contentGroup, IAUISelectionControl selectionControl, Int32 pageSize, IDictionary`2 instanceChangeRecords, IDictionary`2 relationshipChangeRecords, IExtendedParameters extendedParameters) at Bentley.EC.Presentation.Content.ContentServiceInProcess.UpdateContents(RepositoryConnection connection, ContentServicePageableContainer& updatedContentServicePageableContainer, ContentGroup contentGroup, IAUISelectionControl selectionControl, Int32 pageSize, IDictionary`2 instanceChangeRecords, IDictionary`2 relationshipChangeRecords, IExtendedParameters extendedParameters) at Bentley.EC.Controls.ContentServiceContentModelAdapter.UpdateModel(ContentServicePageableContainer& updatedContainer, IDictionary`2 instanceChangeRecords, IDictionary`2 relationshipChangeRecords)Caught: at Bentley.EC.Controls.ContentServiceContentModelAdapter.UpdateModel(ContentServicePageableContainer& updatedContainer, IDictionary`2 instanceChangeRecords, IDictionary`2 relationshipChangeRecords) at Bentley.EC.Controls.ContentModelObserver.UpdateModel(IDictionary`2 instanceChangeRecords, IDictionary`2 relationshipChangeRecords) at Bentley.EC.Controls.ContentControl.ListGridContentPanel.OnUpdate(IDictionary`2 instanceChangeRecords, IDictionary`2 relationshipChangeRecords, ContentUpdateStatus& updateStatus) at Bentley.EC.Controls.ContentControl.ContentPanel.ContentControlUpdateEventHandler(Object sender, EventArgs e) at Bentley.EC.Controls.WPF.UpdateTimer.TickHandler(Object sender, EventArgs e) at System.Windows.Forms.Timer.OnTick(EventArgs e) at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at wWinMainCRTStartup() at wWinMainCRTStartup()
Seems to be when I load a reference file, Im seeing a pattern of events.Ill upload more details when I get a moment...
Thanks for your help
If you are not on the latest version, can you try upgrading to Update 16
MicroStation CONNECT Edition (Full) x64 (SES) Update 16 (English) - Version:10.16.00.80
