Hello, I cant seem to find the information I need. In trying to set my dim style ( which changes every time I open another drawing), the Height and Width factor I guess it is, isn't showing in inches. it shows as something like 0:1. So when I put in .125 or try to, it goes to 10:5. How do I change this?
That would actually be your working unit settings I believe. Those are found under design file settings.
If you dimension style isn't coming from a DGNLIB file automatically, it will be different for each file because dimensions styles are saved on a per-file basis.
MaryB
