When the preference is set to Walk forward/backward it doesnt seem to work in connect??
Hello Dan,
Can you please provide a few more details. I am able to walk with the CTR + Wheel action.
can you try after resetting the Preference by using the 'Defaults'
Nilesh
Hi Nilesh,
This does not work, my colleagues also have the same issue.. It works fine in V8i...
The default seems to be Zoom in/out and wont update..
Found the issue you need camera turned on in view attributes. But it changes the view to perspective.. Didn't have this problem in V8i
Walk requires a perspective view, the best you can do in an orthographic view is zoom in/out, which is what happens in MicroStation Connect.
In V8i ctrl+wheel didn't seem to do anything useful in an orthographic view when I just tried it, it sort of slowly panned up/down in an iso view, in a top/front view it appeared to do nothing...
Brien Bastings said:ctrl+wheel didn't seem to do anything useful in an orthographic view when I just tried it, it sort of slowly panned up/down in an iso view, in a top/front view it appeared to do nothing...
Brien,
To actually understand what is happening to the camera when you manipulate the view controls try the following:
Now when you make changes to your active view you will be able to see the behavior of the view cone in the other views.
Regards,Ron
