In some 3D models, all elements disappear when zooming in past a certain level. All elements also disappear when rotating the model. I am using the latest connect edition of MicroStation PowerDraft.
Hi Erfan,
Erfan Abdollahi said:all elements disappear when zooming in past a certain level. All elements also disappear when rotating the model
I'm presenting several possible solutions:
You can use CTRL+B to open View Attributes and check this:
For this option it's better to restart Powerdraft after turning off the two options.
Hope this helps and regards
José
Answer Verified By: Erfan Abdollahi
Hi José. Thank you for your detailed response.
It seems to be an issue with display depth. When I set to -100000 and 100000, it works but resets itself if I use the fit view function. I will keep changing the settings and hopefully get it fixed. But at least I now have a workaround with your solution. Thank you.
Erfan Abdollahi said:but resets itself if I use the fit view function
In View Attributes check if the Clip Back and Clip Front are turned off:
Please click Verified Answer on the posts that helped you so others in the community can find them easily.
Key-in dp worked for me, thanks.
