With Dark theme on, I cannot maximise a view in U16 by double clicking the view's title bar, which works normally with dark theme off.
Best regards,
Tuan Le
Hello Tuan,
Thanks for reporting the Issue, It looks like an defect, we will report defect for same and notify you shortly.
Dhiraj Badgujar
Yes, that thing, much like Connect, is essentially still in Beta. They appreciate you reporting any defects, they will fix them eventually. Unpaid beta testers is what we are.
