Using the Linear Pattern to create a line with an X symbol. Is there a way to change the distance between cells (X’s)? Maybe there is a better way to do this in Microstation, I’m open for suggestions.
PowerGeopak SS2, v 08.11.07.615
Creating a custom line style would be preferable to using a linear pattern, especially if you will be modifying the line end points, etc.
HTH
-B
Answer Verified By: Robert Watson
Thanks Brien. I'll have to look into creating one. Will be my first with Microstation.
PowerGeopak SS10 v08.11.09.918
Will be well worth your time to drill down on 'create custom linestyle' It is a bit involved. There is stuff out there on the interweb, youtube videos, etc. to help you. Top Tip- If you incorporate text in your linestyle, drop it to components (drop text) before you create the Point.
you can also import from acad linestyle but the -x- is the easiest to make in notepad... as .lin file.
google this and it take you 15 mins and works first time.. the linestyle creation tool gui is just too complex.. I used 20 times in 30 years and unless you use it alot you just forget is extremely powerful but such old interface not easy to master.. too much complexity ,,, we need a simpler tool for simple linestyle... btw search any DoT website and they will have the -X- for abandoned linestyle you can download and import just that one on its own... but then you have to share it with clients and fellow employees or they wont see it in dgns...
If you still want your linear pattern... if I remember right you have to design the cell to give what you want..
In ask inga since your using V8ss2 there is an mdl that has some very usefull tools and one is to do fake line style with Text like --OHP---
it has some settings but pretty cool for one offs just to get a plan out the door on time
Here is the link copy and paste in the search and there is a video of how it works
communities.bentley.com/.../msm-tools-for-microstation-v8
.. ...here is the down load link
https://communities.bentley.com/askingapics/273.zip
only drawback is doesnt use level names only the old 1-63 but you can create level first then make it with tool and rename level .. still works for me in V8i ss3 and 10
Lorys
If files are being sent to our client will I have to provide any custom lintype files or will these be imbedded in dgn files
