Is it possible to undo a solid extrusion to return the model back to only the profile? I have already saved and closed the file, and am opening it back up and would like to get rid of the solid extrusion and just retain the profile.
Hi Steve,
It's always best to follow Forum best practices and tell the forum which version are you using. The solution (if any) isn't always the same.
Steven Tissier said:Is it possible to undo a solid extrusion to return the model back to only the profile?
If working with any CE version and with parametric solids it's possible to show the original profile.
See here and here - this second one it's a solution for a different question, but you see the glyph in solid and profile center where to Show Input Element - the profile that you want.
Please click Verified Answer on the posts that helped you so others in the community can find them easily.
Hope this helps and regards
José
Answer Verified By: Steven Tissier
Thanks Jose, between your & Jan's answer I think I will be good. I am working with a parametric solid in Connect Edition btw. I figured out how to edit my signature with program & version info. Thanks for the tip!
OpenBridge Modeler - 10.10.00.85Microstation - 10.16.02.34
Comprehensive 3 Day OpenBridge Modeler Training
Hi Steven,
Steven Tissier said:btw. I figured out how to edit my signature with program & version info.
I recommend to modify the signature to use smaller (and dimmed, in the best case) fonts. To use font, the same as normal text, is in my opinion intrusive, because it's not clear what is text (question / answer) and what is the automatically inserted signature. Compare José's and mine signatures ;-)
Jan
