Is their a way to Delete Defpoints that was per accident imported form AutoCAD?
Hi Neethling,
It's always best to follow Forum best practices and tell the forum which version are you using. The solution (if any) isn't always the same.
Neethling Van Tonder said:per accident
Sure? Without knowing anything more about your issue, defpoints are the points where the element of dimension is pointing at.
This element don't exist in native dimensions of Microstation.
So you should convert the dimension style that you copied / imported to a native DGN style. For that use dimension style remap - see here for help.
For that you can change the style of each dimension element one by one but normally it's best to use RMB (right mouse button) on top of the dimension style inside Dimension Style Dialog and click remap and choose the one that you desire and all the elements using the old style will change.
After that in principal you can delete the Defpoints level inside Level Manager which should lost the bold feature in is name since it's not in use anymore.
I see here that you posted the same question in another forum. Why are you asking the same question in a new forum? This isn't productive.
Please click Verified Answer on the posts that helped you so others in the community can find them easily.
Hope this helps and regards.
José
search for envision cad, Rod wing has freeware tool to find and delete zero length lines ( def points )
Lorys
Lorys said:find and delete zero length lines
Here's a freeware VBA macro. I believe that it works with both MicroStation CONNECT and V8i...
Be aware that in a DWG file, the dimensions are associated to the defpoints and not the actual object. When you delete the defpoints you are braking the dimension association.
something you just have to live with in msnt is breaking dimensions .. sometimes it the only way to get a dimension to look right on prints without spending too much time... as long as its reading true I can live with busted dims.. I think the dim tools in acad are better and mstn hasn't really improved much over the last 25 years compared to our acad cousins when it comes to dims and text tools ... but this is a big generalisation....
