I can't find the keyin anymore:
annotationscale change ...
Where did it go? What is the alternative?
Configuration variable "MS_ANNOTATIONSCALE_PROPAGATION=NEVER" is removed in V8i. In V8i Annotation Scale is a per model property. You can not have multiple annotation scale in a model.
For changing annotation scale of annotations having different annotation scale from active model, you can use keyin "Model Set Annotationscale".
I hope you are wrong that the configuration variable has been removed, in XM I am using it all the time.
The result is that I am having problems opening my xm files in v8i, the annotationscale is changing all the time.
I would like to make use of the configuration variable MS_ANNOTATIONSCALEPROPAGATION=NEVER in v8i, how can I do that.
I did copy the next text from v8i help, the configuration variable is still available.
Controls the propagation of a model's annotation scale.
If set to PROMPT, you are prompted to accept or reject the propagation to existing annotations.
If set to ALWAYS, the scale will be automatically propagated.
If set to NEVER, the scale will not be propagated.
Don't remove the text from v8i help, removing the configuration variable from v8i help is no solution me, I didn't ask for that.
How do you know that MS_ANNOTATIONSCALEPROPAGATION=NEVER has been removed from v8i? Where did you read it? What is the reason?
Do you have a list of all removed keyins and configuration variables in v8i?
