I can't find the keyin anymore:
annotationscale change ...
Where did it go? What is the alternative?
Mahendra Patole: For changing annotation scale of annotations having different annotation scale from active model, you can use keyin "Model Set Annotationscale".
That doesn't work for me, if I am making use of the keyin:
Model Set Annotationscale 100
The active annotationscale will be set to 1:100, all annotations in the model is changing to 1:100
Model Set Annotationscale 200
The active annotationscale will be set to 1:200, all annotations in the model is changing to 1:200
