Currently using Microstationv8i select 3 ver 09.11.09.587 and would like to know does MicroStation have some title block cells for us to use if so, where?
Thanks.
Steve Smith said:I would like to know does MicroStation have some title block cells
Most companies specify their own title block design. It's usually nothing more than a few boxes drawn with shapes or lines. There may be a company logo image, and perhaps a drawing border as well.
Boilerplate text in a title block (e.g. organisation name) is created using text or text node elements. The trickiest part is deciding how to compose text that will change with each customer, project and revision. If you plan to automate title block text updates, then consider...
In your considerations, pay attention to MicroStation sheet models, which are there to help accelerate drawing producting
Continuing on from the information Jon has provided, you might like to look at the sample borders provide within the MicroStation installation.
Using the Delivered Sample Borders
I believe these may have only been included in the CONNECT versions which you should look at due to discontinued support for the older version of MicroStation V8i.
Desktop Applications Support Policy
Apparently with my latest version version of MicroStation and my connect 10.14.00.109 and Microstationv8i select 3 ver 09.11.09.587 these files are corrupted. I tried reloading the software and I cant open them.
Could you upload the dgn so I can get it?.
MicroStation V8i (SELECT series 3) - Version 08.11.09.578
Microstation Connect 10.14.00.109
Andrew Bell said:you might like to look at the sample borders
MicroStation CONNECT Help says: When you install the product, a number of sample border files are delivered to the ANSI, Architectural, and ISO subdirectories of the ..\MicroStation\Default\Borders directory.
My installation of CONNECT Update 16 doesn't have that Borders directory...
Directory of C:\PROGRA~1\Bentley\MICROS~1\MICROS~1\Default 28/06/2021 11:35 . 28/06/2021 11:35 .. 28/06/2021 11:35 Cell 28/06/2021 11:35 Colorbooks 28/06/2021 11:35 Data 28/06/2021 11:35 Dgnlib 28/06/2021 11:35 DWG 28/06/2021 11:35 Fonts 28/06/2021 11:35 GUI 28/06/2021 11:35 Image 28/06/2021 11:35 Materials 28/06/2021 11:35 menus 28/06/2021 11:35 NPR 28/06/2021 11:35 pltcfg 28/06/2021 11:35 Seed 28/06/2021 11:35 Symb 28/06/2021 11:35 System 28/06/2021 11:35 Tables 0 File(s) 0 bytes
Steve Smith said:Apparently with my latest version version of MicroStation and my connect 10.14.00.109 and Microstationv8i select 3 ver 09.11.09.587 these files are corrupted.
No, they are not. I tried MicroStation CE Update 14 (specifically 10.14.02.01) and I am able to open examples with borders without any problem.
Jon Summers said:My installation of CONNECT Update 16 doesn't have that Borders directory...
What about C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Example\WorkSets\MetroStation\DGN\Borders\?
With regards,
Jan
