I unfortunately had mistakenly pinned the Level Manager dialogue box to the side and now it won't open the dialogue box when I click on the tab and the roll out tab is tuck on the side
How can I re-set this? Be grateful if someone can provide help with resolving this.
Not sure why this Level Manager tab is not expanding when you select it. Usually when you hover over this tab it should be displaying the full dialog. If you wanted to reset back to default the User Preference File (UPF) you might like to follow the workflow on this Wiki.
How To Reset User Preferences and Delete MicroStation's Temporary Files
Don’t mess with your preferences. If you follow Andrew’s instructions, you will have to reset your preferences.
Exit MicroStation Delete the “Personal.docking.xml” file Restart MicriStation and reopen the dialog.
C:\Users\<YourUserName>\AppData\Local\Bentley\MicroStation\10.0.0\prefs\Personal.docking.xml
Thanks Andrew.
Many thanks, this is helpful and it worked
Gordon Young said: this is helpful and it worked
Please acknowledge a positive outcome with the This Answered My Question button.
