Hello, When I import a parametric cell into my 3D working file, I can give it the name of the level but not the attributes (color, line thickness, etc.) Can you help me ? I thank you in advance. Cordially, Jean-Marc Truffet
I assume this is a version of MicroStation CONNECT Edition that you're using but which version?
MicroStation Forum best practices
If you're importing a parametric cell is this coming from an external source or another software package?
It would be helpful if you could provide example files, screen captures along with a workflow for how this is being performed.
I'm working on the Connect Eddition version. I created the parametric cells.
1) 2)3) 4)
Hi Jean Marc,
This used to be possible with old parametric cell behaviour but was changed as it didn't work for lots of users.
Please vote in the ideas for this functionality to be re introduced: https://microstation.ideas.aha.io/ideas/MSR-I-656
Aimable
