I loved this keyin to turn all the levels on (set levels on all) , but as on maybe a month ago or so, it no longer works. Any idea why?
Your keyin is incomplete. You also have to specify the view in which to turn on the levels
Updating your keyin to this should do the trick to turn on the level display in all open view windows.....
set levels on all;selview all
Without that addition to your keyin you have to click a data point in a view window for the levels to be turned on
Rod WingSenior Systems Analyst
I have used set levels on all; for years this keyin has worked on it’s own.
I have tried adding "selview all;" but no difference in result.
Whether I use
set levels on all;selview all or
set levels on all;
it prompts me to select view, so when I click a data point on any one view, nothing happens.
It just gets stuck in select view prompt.
Microstation select series 10 ver 08.11.09.919
also have
CONNECT Ed Update 17
Version 10.17.02.61
Is it that way in every file, or just a single file?
Could it be that you have some command/macro active that isn't understanding the keyin?
Try this keyin...
null;set levels on all;selview all
The NULL keyin clears the command buffer.
Yes, you are right, I noticed it does work in some drawings but not on others. But null did not help. Mostly an issue in drawings I made, as opposed to other people's drawings. Not sure what is unique about my drawings. maybe I will post a drawing sample.
here is a sample dgn that has that issue.
sample - Copy.dgn
