I loved this keyin to turn all the levels on (set levels on all) , but as on maybe a month ago or so, it no longer works. Any idea why?
The other odd thing that is happening, if I turn a level off and soon after I activate view previous command (by keyin or icon) it does not turn on that preview level. The only way to turn it on is to use the Level display dialog box.
Microstation select series 10 ver 08.11.09.919
also have
CONNECT Ed Update 17
Version 10.17.02.61
Does keyin ON=ALL work?
Either way, sounds like I would try deleting my user preferences. https://communities.bentley.com/products/microstation/w/microstation__wiki/8978/how-to-reset-user-preferences-and-delete-microstation-s-temporary-files
Matt
I can replicate your issue in this file, but I can't find what is causing it.
Rod WingSenior Systems Analyst
no "ON=ALL" does not work in those specific drawings either.
Preferences is not drawing specific. My my issue is drawing specific, so I doubt that will help. Also I don’t want to re setup all my preferences.
