Hi all
I have just upgraded to Connect from V8i and all my borders are tags. But what I have now noticed is that when editing tags I can only edit them with tag editor and cant use text editor anymore for some reason. As soon as I use text editor with the tag the text in the tag changes and it reverts to the active text attributes. It doesnt keep the text attributes of the tag.
Can we no longer use text editor for tags?
It is always a good idea to provide details of the MicroStation version number you're currently using as this can affect any answers provided to assist you.
MicroStation Forum best practices
As there have been a couple of recent Defects raised for issues with the editing of tags in MicroStation CONNECT Edition it would be a good idea to first ensure that you have the latest Update 16 version. It would also be helpful if you could provide an example file and screen capture for testing of your issue.
Hi Chantel,
Chantel Jordaan said:I have just upgraded to Connect from V8i
As Andrew wrote: Without knowing what MicroStation CE version do you use, the discussion cannot be efficient. There have been about 20 CE versions released so far and different tags functionality was fixed in different version.
Chantel Jordaan said:As soon as I use text editor with the tag the text in the tag changes and it reverts to the active text attributes. It doesnt keep the text attributes of the tag.
I do not see such problem when editing tags in current MicroStation CE Update 16.
With regards,
Jan
Hi Jan and Andrew
Thank you for the reply, I believe its update 15 version 10.15.02.11. I will speak to our administrator and see if we can get an updated release.
Thanks Andrew, Thanks for sending the best practices through. I have noted that now for future posts. As my comment below, I will speak to my administrator to see what we can do about a newer release.
